UJK Compact Router Table with Laminated Top
- UJK Compact Laminated Router Table Top
- Low friction phenolic laminate surface
- Aluminium extrusion track for mitre fences and accessories
Customers Also Bought
Package deal comprises the UJK Compact Laminated Router Table Top, UJK Compact Router Table Fence and UJK Compact Router Table Leg Stand.
The UJK Compact Laminated Router Table Top is high-grade birch ply with a hard wearing, low friction, phenolic laminated surface. The ply core ensures the top will remain flat throughout its working life, while the laminated top ensures workpieces glide smoothly. An extruded aluminium track inset into the table top includes a standard 19mm track for the use of a mitre fence and a T-track slot for other jigs and accessories. The 230 x 306mm central aperture will accept any of the UJK router table inserts as well as the UJK router elevator. The top measures 600 x 400.
The UJK Compact Router Table Fence is a single piece of aluminium extrusion. It comes with a 63mm dust port for efficient extraction from above the table. T-slots at both the top and front of the fence allow for the fitting of other accessories or guards. An adjustable transparent guard is included for your safety. The infeed and outfeed fences attach to either side of the aluminium section. The central aperture is variable to accommodate cutters of different diameters. The fence assembly includes scales for attachment at either side of the table and along the top of the fence. The fence measures 789 x 90mm.
The UJK Compact Leg Stand with splayed legs is of sturdy construction, very stable and the size offers portability around the workshop or on site. There is provision for storage of a mitre fence assembly. It is 370mm high, with a footprint of 580 x 390mm.
- Thick birch ply core, will not warp over working life
- Accepts any UJK table insert
- UJK Compact Router Table Fence
- Adjustable in-feed and out-feed fences
- T-slot for accessories at the top and front of the fence
- Graduated scale provided along top of fence
- Transparent 63mm dust port for efficient extraction
- UJK Compact Router Table Leg Stand
- Sturdy steel components with good mobility
- On-board storage for mitre fence
- Footprint of 580 x 390 x 370mm high
- Site or workshop use
