UJK Corner Chisel
103864
From £14.88 £12.40
6 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 14th May
  • Trim routed hinge recesses, only requires a sharp tap with a hammer
  • Leaves a neat square corner for a professional finish
  • Tungsten steel blade sharpened to a perfect 90°
  1. UJK Corner Chisel
Total:
£129.52 £107.93
Routing a hinge or lock plate recess always leaves you with rounded corners. You could square off the corners with a normal chisel. However, the UJK Corner chisel is much quicker and highly accurate. Clean, perfectly square corners give the job a professional, clean looking finish.
The blade is tungsten steel, sharpened to a perfect 90° corner. The steel body has locating lugs, which automatically align the chisel. A sharp tap with a hammer and the spring loaded chisel cleanly cuts the corner. Pare away the little piece of waste for a perfect cut every time.
4.80 6
