£328.96 £274.13
Out of stock
  • Construct your own custom-made router table
  • Add precision and versatility to your routing projects
  • Router table allows use of wide range of cutters
Customers Also Bought
Total: £428.92
The UJK Custom Router Table Kit comprises RT-100 router fence, 600mm length of mitre fence & T-slot track, 915mm length of dovetailed mitre slot track, a UJK aluminium router table insert and a pack of 10 x M6 pronged T-nuts.
This kit includes the vital hardware needed to construct your own custom-made router table. A router table adds precision and versatility to your routing projects. With a router table, you can make use of a wider range of available cutters, greatly adding to your router’s potential. This kit reduces the cost of a router table and allows you to design it to custom fit your own workshop. For guidance on which cutters we used, download our free PDF plan below, under User Manual.
UJK RT-100 Router Table Fence
Made from anodised aluminium alloy extrusion, the UJK RT-100 router table fence has left and right hand phenolic adjustable fence wings. The RH wing can be micro adjusted with nylon shims. The fence can accommodate cutters up to 90mm max in diameter. It has a dust hood with a 62mm OD hose outlet. The two knurled hand knobs locate into the UJK mitre fence and T-slot track.
UJK Mitre Fence & Tee Slot Track
The kit is comes with a 600mm length; this will need cutting in half, one piece for each side of the fence. This anodised aluminium extrusion from UJK has a T-slot allowing you to position and secure the router fence. All it requires is a routed slot to sit in for a flush fit with the tabletop.
See User Manual Download for dimensioned drawing.
UJK 10mm Aluminium Router Table Insert Plate
This 10mm aluminium insert plate for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The insert plate will accommodate most portable routers and should be drilled to individual requirements.
UJK Mitre Slot Track
Positioned parallel to the router fence, this mitre slot track allows you to use a mitre fence for end grain routing and a variety of other jigs. The external measurements overall are 915mm(36") long, 31 x 12.7mm deep and the slot is 19 x 9.7mm deep.
Threaded Pronged T-Nuts M6
Threaded pronged T-nuts are simple but useful items for fixing the table top or constructing jigs. To insert simply drill an 8mm hole and tap the insert home, pack of 10.
  • Design a table to fit your own workshop and needs
  • High quality, well designed hardware from UJK
  • Free PDF download of plan, see User Manual
This product is on page 202 of the Axminster Tools Catalogue View Page 202
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
