UJK HDF Valchromat Top for Bench Dogs
102537
From £134.98 £112.48
  5. Half Star
49 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 16th Jul
  • For work holding while sawing or routing with guide rails
  • HDF Valchromat work surface 1,102mm x 718mm
  • 11 x 7 grid of perfectly aligned 20mm chamfered bench dog holes
  • Holes suitable for bench dogs, dog clamps and other accessories
  • Drop-in snug fit into UJK workbench frame and Festool MFT base
  • Made in the UK
  1. UJK HDF Valchromat Top for Bench Dogs
Total:
£282.93 £235.77
The UJK MultiFunction workbench top is 18mm thick Valchromat. Valchromat is not MDF it is a type of HDF, which is harder and denser than standard MDF and more resistant to impact damage. Valchromat has greater internal cohesion, higher mechanical strength and is more moisture resistant than MDF. The UJK workbench top has a grid of 20mm plain chamfered dog holes: 11 holes by 7 holes. These holes are CNC machined to guarantee accuracy, aligned lengthways and widthways with the rows perfectly square to each other. These dog holes allow you to use bench dogs and many other accessory clamps, guide rails and stops to hold, saw, rout and machine your work with spot-on accuracy. Made from 18mm thick Valchromat, the 1,102mm x 718mm Isometric Top is a snug drop-in fit in the UJK MultiFunction workbench frame or the Festool MFT base. Making it a suitable replacement for the standard Festool top. A finish can be applied to add extra protection to the top.
This workbench top is certified by the Pan European Forest Council (PEFC).
British Made British Made
4.50 49
