PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Create portable cutting boards in less than 30 minutes
With over 200 years of combined experience in the woodworking industry, UJK continues to develop tools and technologies that help to make your life easier.
A collaboration between Axminster Tools and Peter Parfitt, the ever popular UJK Parf Guide System allows you to create a custom workshop benchtop or portable onsite cutting work surface whenever the need arises.
Using this piece of kit and an accurate pattern of 20mm holes, you'll achieve perfect 45 and 90 degree cuts with a guide rail and track saw.
Based on the Pythagoras theorem for infallible accuracy, the UJK Parf Guide System produces guaranteed results, every time.
Quick and easy to use, the Parf Guide System is perfect for when you need to produce bench top track saw cutting stations on site in less than 30 minutes.
The Parf Guide System includes two Parf sticks and all necessary guide and drill bits to ensure you get guaranteed straight cuts wherever you are.
Making consistent right-angled cuts are what every woodworker strives to achieve
If you’ve got the UJK multifunction table, some Parf dogs and a track saw and guide you’ve got a pretty good chance of achieving this. That’s great if you have one of those tables, but what if you want to build your own workstation or multiple workstations?
Developed by UJK and Peter Parfitt, the Parf Guide System gives you a simple way of producing a pattern of accurate 20mm holes. This allows you to make as many workstations as you desire. Most importantly accuracy is assured and this jig will not allow for cumulative errors due to the way it works.
How It Works
We use Pythagoras’ theorem and the 3, 4, 5 triangle to generate our natural squareness. The Parf Guide System uses two Parf sticks together with a 3mm drill guide and 3mm drill bit to create an accurately placed series of holes with the rows at perfect right angles to the columns. Once the pattern of 3mm holes has been completed, the holes need to be enlarged to 20mm using the special drilling jig and boring bit supplied with the kit.
Guarantees perfect 45° and 90° cuts, every time
Developed by UJK and Peter Parfitt, the PGS is a joint development
Perfect for onsite work
Includes two Parf sticks and two UJK low profile dogs
Includes all necessary guides and drill bits
All components made, checked or assembled in Axminster for UJK
Downloadable box plans available under 'User Manual 2' section
Plans on how to make the Isometric MFT3 top available under 'User Manual 3' section
