PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Immediately improve your cut quality, accuracy and safety; the UJK Precision Mitre Gauge system is the ideal upgrade for bench saws, bandsaws and router tables.
Secure fixing
Any play between the mitre slot and the bar will impact how your mitre joints fit together. The UJK bar features adjustable sprung ball grub screws for a perfect fit, resulting in the ultimate precision cut.
Easy, accurate set up
The useful presets (positive stops) enable common mitre angles to be achieved with speed and ease. When more complicated angles are required the easy-to-use scale allows the quadrant to be locked at any angle within its range.
Comfortable control
The anodised aluminium fence rail is 458mm long, providing greater support, allowing multiple cuts to be made with increased control and safety.
Repeatable accuracy
The flip-over length stop slides along the top of the fence and can be locked anywhere along its length. This solid brace enables repetitive cross cuts to be set up and carried out with ease and accuracy.
Widely compatible
The UJK Mitre Gauge system fits most bench tools with a standard ¾" x ⅜" (19 x 9.5mm) table slot. If your machine does not have a T slot, the locking washer can be removed.
This mitre gauge system is made from 5mm steel plate and features positive stops at 0°, 22.5°, 30°, 45°, 60°, 67.5° and 90°. Simple to adjust with a spring loaded plunger stop and able to be set at any other angle between 0-90° as required.
The other main feature is the anodised alloy fence, fitted with an adjustable flip-over length stop. This fence can be slid along the gauge body by releasing two thumb screws. The 320mm bar can be fitted to a standard 3/4" x 3/8" (19 x 9.5mm) table slot; the locking washer can be removed if required.
This mitre gauge will improve accuracy when cross or mitre cutting on many machines or router tables.
Features positive stops at 0°, 22.5°, 30°, 45°, 60°, 67.5° and 90°
Anodised aluminium fence rail slides on fence body
Flip-over length stop for repeat accuracy
Indexing stop system is adjustable for total accuracy
Makes it easy to quickly cut a perfect mitre joint
Standard 3/4" x 3/8" (19 x 9.5mm), 320mm bar, removable locking washer
