UJK Progrip Clamp
UJK Progrip Clamp
- Rigid extruded aluminium profile guides the power tool
- Guarantees a straight cut when sawing or routing
- A purpose-made, obstruction-free solution
Save time, effort and money
Get things straight with the UJK Progrip Clamps! If you carry out repetitive work, UJK Progrip Clamps will save you time, effort and money. Easy to use, simply clamp onto a workpiece and guide your power tool to create perfectly straight edges and accurate cuts. Sanding can also be made easier, when the correct accessories are purchased. For convenience, there's three different clamping capacities to choose from.
With these optional accessories, the Progrip Clamps become a very useful addition to any workshop
Precision Grooving Jig
This UJK jig allows you to cut grooves, dadoes (through or stopped) and rectangular cutouts. Designed for use with the Progrip Clamps, it offers far greater accuracy and precision than previously possible.
Adaptors
Keep your wood firmly in place with the use of adaptors. Choose from either back to back adaptors which clamp work directly to your workstation or side by side adaptors which allow you to join clamps of different lengths.
Wide Jaw Block
These wide clamping boards reduce clamping pressure marks on softer wood. Supplied in a pack of two, they fit easily over the jaws of your Progrip guide providing a more evenly spread clamping surface.
Many everyday power tool sawing or routing tasks involve cutting a straight line. There is always the problem of how best to guide the tool along a straight cutline. These guide clamps are a perfect alternative to trying to use a straight bit of scrap wood and a couple of G-clamps, which invariably will get in your way. UJK Progrip guide clamps are a purpose-made, obstruction-free solution. UJK Progrip guide clamps offer a versatile and secure method for guiding routers, circular saws, jigsaws etc. The positive clamping mechanism sits below the top of the clamp. The mechanism has 3 progressive clamping pressures, allowing for final positioning before securely locking. It exerts plenty of pressure ensuring the guide clamp will not move in use. The guide clamp’s extruded aluminium profile is rigid. The guide clamp will not bow in use ensuring your power tool will follow a straight line, not a curve.
