These all-metric threaded M6 or M8 T-slot bolts have 18 x 12mm heads and are zinc plated. They are a direct fit into UJK T-Track in the UJK Track and Stop Kit, the UJK Universal T-Track as well as the T-Track on the UJK Router Fence and many similar sized 1/2" T-tracks. Both threads are available in 3 lengths: 25mm, 50mm or 75mm. The metric thread (rather than the usual UNC thread) opens up a wider range of options, especially with other easily available metric threaded fittings. Supplied in packs of 10.
UJK
UJK T-Slot Bolts (Pkt 10)
| Thread | M8 |
| Web Attribute Set | Router Accessories & Hardware |
| EAN Barcode | 5052511109241 |
