Reusable respirators, specially designed to give an excellent comfortable fit, they have a soft, pliable silicone face seal and unique adjustable head harness. The 3M Cool Flow exhalation valve is fitted to reduce breathing resistance helping to minimise heat build up inside the mask; the special thin nose bridge gives improved flexibility and reduced pressure.
3M 7500 respirators are reusable. They can be easily be stripped, cleaned, maintained and reused. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. Two lightweight filters, one each side of the face piece click securely in place using a simple bayonet system.
Supplied without cartridges or filters so that you can choose the correct one for your working environment. The filters can be fitted in one of three configurations: 1) gases and vapours, 2) gases, vapours and dust, 3) purely for dust.
Please note filters need to be purchased separately.
EN140:1998/CE.
Soft face seal, comfortable fit; adjustable head harness
Cool Flow exhalation reduces breathing resistance
Filters available for protection against a variety of airborne hazards
