These clamps offer outstanding performance through the innovative use of a 2-way ratchet in place of the usual static handle. The F-clamp design allows for fast positioning. All it takes then is a few movements of the ratchet to achieve a high clamping pressure.
The design of these clamps makes them fast, easy to use and wholly convenient. The horizontal handle offers better control and feel for the clamping pressure. At the same time, it is easy to park out of the way if space is limited.
Capacity x throat depth: 600mm x 120mm, max clamping force over 700kg.
2-way ratchet handle for rapid tightening, clamping force over 700kg
Outstanding performance; fast and easy to use
Ratchet offers control with good feel for clamping pressure
