Arbortech Mini TURBO Plane Kit
- Ideal tool for accurate repeatable shaping
- Smooth and fast cutting action
- Can be run against a template for accuracy
- Supplied with rubber backing pad and sanding discs
- Includes M5 fixing screws and tools
- Will fit the Arbortech Power Carving Unit and most 100 or 115mm angle grinders
Makita GA4530KD Angle Grinder 115mm with Diamond Disc and CaseFrom ÂŁ76.98 ÂŁ64.15
UJK Level BoxSpecial Price ÂŁ19.98 ÂŁ16.65 was ÂŁ24.98 ÂŁ20.82 Save ÂŁ5.00 ÂŁ4.17
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ19.79 ÂŁ16.49 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ10.19 ÂŁ8.49
Axminster Professional Master Precision TapeSpecial Price ÂŁ7.49 ÂŁ6.24 was ÂŁ9.98 ÂŁ8.32 Save ÂŁ2.49 ÂŁ2.07
The Arbortech Mini TURBO™ Plane Kit is a revolution in wood sculpting. This unique tool is designed to fit the Arbortech Power Carving Unit and most 100mm or 115mm angle grinders using the supplied extension adaptor.
The blade is precision machined from high quality steel and fitted with 2 tungsten carbide teeth. The cutting teeth are rotatable, resharpenable and replaceable but it may be some time before replacements are required.
This unique tool is great to use freehand or with guides and templates for accurate repeatable shaping. The comprehensive kit includes the Mini TURBO™ blade, extension adaptor, 3 assorted sanding discs, a rubber backing pad, M5 fixing screws and washers plus torx and hex drive keys.
EAN Barcode | 9313478320022 |
