From £17.98 £14.98
In Stock
  • Dissolves resin, pitch, goo, gunk, crud, gunge and other nasty residues
  • Formulated to clean saw blades, router cutters etc
  • Helps maintain cutter performance
Customers Also Bought
Give your TCT some TLC. It is just as important to clean saw blades and router cutters regularly as it is to keep other hand edge tools sharp.
Friction causes saw teeth and cutter edges to heat up in use. This allows resin in the timber to weld itself onto the cutting tips, increasing the friction and making the problem worse. Eventually the build-up it will affect cutting performance and the finished surface.
Keeping your blade clean can make a big difference in its performance. The build-up of gunk often makes a blade appear prematurely dull. A thorough cleaning can rejuvenate its performance.
Axcaliber Blade & Bit Cleaner is a special formula, thoroughly tested in Axminster’s own workshop and in some staff home workshops. It dissolves resin, pitch, goo, gunk, crud, gunge and other nasty residues, leaving your blades clean. Use on a regular basis to prolong the life of your expensive tooling.
Axcaliber Blade & Bit Cleaner comes in a convenient 500ml.
  • Use regularly to prolong a tool's working life
  • Supplied in a convenient 500ml spray bottle
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.30 29
