Axcaliber Dovetail Router Cutter
- Large dovetail cutter useful for dovetailed grooves
- 14° slope matches that UKJ dovetailed T-track
- Ideal for making custom made jigs or router tables
- Produce a chamfer on an edge
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
A large dovetail cutter, useful for cutting dovetail grooves. The 14° slope matches that of the UKJ Technology dovetailed T-track, when producing custom made jigs or router tables.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 22.2 mm (7/8") |
EAN Barcode | 5052511029037 |
K = Cutter Angle | 14° |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 22.2 mm (7/8") |
