Axcaliber FineLine PTFE Coated Handsaw
From £11.68 £9.73 was £16.58 £13.82 Save £4.90 £4.08
51 Reviews
  • Triple diamond ground FineLine teeth, super sharp and long lasting
  • Rigid blade with low friction, rust resistant PTFE coating
  • Heavy duty soft grip comfort handle
  • Choice of length and tpi
'Hardpoint' handsaws for timber & plastics
These razor sharp, triple diamond ground teeth cut with amazing speed. The blades are made from 1mm thick steel and have a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. The saw is fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles. Perfect for both indoor and outdoor protected timbers.
5.00 51
