Axcaliber FineLine PTFE Coated Toolbox Saw 11tpi - 380mm
101297
101297
From £12.68 £10.57
22 Reviews
In Stock - Ready to dispatch
  • 380mm, perfect length for the toolbox, PTFE low friction coating
  • Cut wood, plywood, chipboard, PVC or plasterboard
  • Hardpoint teeth have 3 cutting edges for a fast, super clean cut
Pull and push
Each tooth has three cutting edges. This tooth design produces a fast and very clean cut, both on the pull and the push stroke.
A saw for all seasons
The low friction PTFE coating not only protects the blade from corrosion, it also makes it glide through even wet timbers.
Staying sharp for longer
The technologically advanced diamond grinding process ensures a precise tooth form, with impulse hardening offering greater durability and longer life.
More than a saw
Fitted with a heavy duty two part comfort handle that incorporates 45° and 90° angles for fast marking out.
'Hardpoint' handsaws for timber & plastics
Perfect to keep in the toolbox, as handy as a tenon saw but without any limit to the depth of cut. Hardpoint, FineLine, diamond ground toothing. PTFE coating reduces cutting friction and keeps rust at bay.
4.90 22
