Enjoy the benefits of a router table in a workshop with limited space. The Axminster Workshop Cabinet Router Table is the perfect benchtop router table for a small workshop.
This benchtop router table has a generous work surface of 610 x 400mm, mounted on a fully enclosed cabinet base. When not in use this compact unit could sit neatly underneath a bench or similar area. It saves space as well as offering excellent routing facilities in the workshop or on site. The Cabinet Router Table comes complete with a UJK Technology Universal Sub-Base.
Included is a full width fence with a length stop running in a T-track. The fence wings are adjustable for width and the whole assembly can be moved backwards or forwards in T-section tracks embedded in the table surface. A 63mm dust extraction port and an adjustable safety guard are also provided. The cabinet is made from melamine coated composite material and has two doors with concealed cabinet hinges.
There is also a 19mm T track running across the table, perfect for fitting the UJK featherboards or a mitre fence.
The phenolic insert plate is the same as used in other Axminster router tables and can take a variety of optional insert rings. The Universal Sub Base is designed to accept standard UJK Technology guide bushes and holes for these are drilled with an M4 thread. It is also designed for mounting a very wide range of different routers including Bosch, Makita, Elu, Dewalt, Festool, Trend, Ryobi and Hitachi models to name a few.
Please note; The UJK Router Elevator and UJK Router Table Inserts are not compatible with the Cabinet Router Table.
Space saving benchtop cabinet style router table
Generous sized top gives good work support
Full width fence with adjustable wings and length stop
63mm dust extraction outlet
Phenolic insert plate fitted with UJK Universal Sub Base
