Axminster Workshop AW118CI Cyclone Interceptor
105844
From £189.98 £158.32
In Stock
  • Unpowered cyclone extractor/interceptor for home use
  • Efficiently separates the wood waste from the airflow
  • Uses the cyclone body and waste bin from the AW118CE Cyclone Extractor
  • Easy mobility thanks to the castor wheels
  • Use with a variety of machines from thicknessers to sanders
The Axminster Workshop AW118CI is a stand-alone, unpowered, cyclone dust collector/interceptor. It uses the cyclone and waste bin from the Craft AC118CE Cyclone Dust Extractor. It is designed to be used with a standard High Volume Low Pressure chip extractor to provide the airflow.
Using this interceptor, you can create a wood dust and chip extractor which will handle even fine dusts from drum sanders. You can either use this unit to upgrade your current workshop chip extraction system (with the typical bag filter) or place this unit next to a drum or belt sander to intercept the fine dusts before the air stream reaches the chip extractor.
It has a generous 118L waste bin and castors for easy mobility around the workshop.
It is fitted with 100mm inlet and outlets, which suit many common woodworking machines. We recommend using a High Volume Low Pressure chip extractor with at least a 1.5hp motor, such as the AW82E. It is not suitable for use with a High Pressure Low Volume (vacuum) type extractor.
NB: This cyclone requires dust bags 785mm x 940mm.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.30 39
