Axminster Woodturning Essential Tool Set
106153
106153
From £139.98 £116.65
  5. Half Star
112 Reviews
  • Made in Sheffield UK
  • 6 essential tools for woodturning
  • Quality UK made set represents real value for money
  • Gain maximum satisfaction from a new craft
  • M2 HSS blades correctly ground and ready sharpened
  • Smooth, well-shaped beech handles
  • Set covers both spindle and bowl turning
The ideal starter set for beginners
Every beginner needs an all round chisel set to help kick-start their turning journey, and the Axminster Woodturning 6 Piece Tool Set offers just that.
British Made
These quality chisels feature a hardened M2 HSS steel blade, which maintains a sharp edge far longer than cheaper carbon steel. Each blade is fitted to a smooth, well-shaped beechwood handle for comfort.
Ready and raring to go
Save time and bypass sharpening! The set is correctly ground and ready sharpened, allowing you to head straight to the lathe and turn right out of the box.
All you need for spindle and bowl turning
This set offers not only great value for money, but everything you need to start your turning journey; whether it's spindles or bowls, you’ll be turning stunning pieces in no time.
The set comprises:
20mm roughing gouge
Use to remove the corners of square stock and for initial rough shaping.
19mm skew chisel
Use this skew for planing cuts, trimming end grain, vee and finishing cuts. This chisel has rounded edges to help when cutting beads.
10mm spindle gouge
Gouge for cutting coves and concave shapes.
3mm parting tool
Useful tool for parting work from the waste and cutting deep grooves when sizing.
10mm bowl gouge
Features a deep ‘U’ shaped flute for both shaping the outside and inside of bowls or goblets.
13mm round nose scraper
Use for removing tool marks and refining the shape of a bowl.
Complete your kit
Complement your woodturning 6 piece starter set with other turning essentials from the Axminster Woodturning range.
Choose a chuck
The ever-expanding range of Axminster woodturning chucks now covers almost every type of work-holding requirement. Explore our Chuck packages now!
Read our blog
Take up pen turning
The Axminster Woodturning Pen Starter Kit includes 4 of our most popular twist pen kits, along with 4 different pen blanks.
Find out more
Having chosen your woodturning lathe, the next step is acquiring the right tools. These 6 tools are essential for anyone starting woodturning as a craft. Made in Sheffield UK, the set represents true value for money and will ensure you gain maximum satisfaction from your new hobby. It is the result of collaboration between Axminster and a long established Sheffield tool manufacturer. They come correctly ground and ready sharpened. The blades are M2 HSS steel, fitted to smooth, well-shaped beechwood handles. M2 HSS holds a sharp edge far longer than cheaper carbon steel.
The set comprises:
20mm roughing gouge - for removing the corners of square stock and initial rough shaping.
19mm skew chisel - for planing cuts, trimming end grain, vee and finishing cuts, this chisel has rounded edges to help when cutting beads.
10mm spindle gouge - for cutting coves and concave shapes.
3mm parting tool - for parting work from the waste and cutting deep grooves when sizing.
10mm bowl gouge - with a deep ‘U’ shaped flute both shaping the outside and inside of bowls or goblets.
13mm round nose scraper - used for removing tool marks and refining the shape of a bowl.
Overall length: 340mm (bowl gouge 490mm), handle length: 215mm (bowl gouge 320mm).
British Made British Made
4.60 112
