Axminster Woodturning Eccentric Spiralling Chuck
900093
From £49.98 £41.65
  5. Half Star
75 Reviews
  • CNC manufactured in Axminster by Axminster
  • For Axminster type C jaws and similar jaw designs
  • Fits 8mm deep, 15° dovetail jaws, which adjust to 70mm
  • Turn eccentric and spiralled stems
Create eccentric pieces
Create unique, offset pieces with the Axminster Woodturning Eccentric Spiralling Chuck.
Axminster Woodturning Eccentric Spiralling Chuck projects
Eccentric woodturning is very popular among the turning community. This specialist chuck allows you to change the turning axis of your workpiece, enabling you to create a whole range of beautifully unique pieces, using spiralling and off centre design.
Easy to use
The Axminster Woodturning Eccentric Spiralling Chuck is lightweight and easy to use. It features an index plate, a pivot plate and a dovetail ring. Simply insert the offset screw at your chosen point when setting your offset position and attach the index plate, aligning the index pins.
Use with 100mm Dovetail Jaws (Type C)
The eccentric spiralling chuck fits directly on the 100mm Dovetail Jaws (Type C). This is one of the most versatile jaws and is useful for small bowls and end grain work such as boxes and goblets, suited to eccentric turning designs.
Create unique designs
The possibilities are endless with the eccentric spiralling chuck. Popular projects suited for off centre turning include candlesticks, goblets, jewellery, box designs and more! The potential for creating beautifully unique and eccentric pieces is unlimited.
Project inspiration
British design and engineering
The Eccentric Chuck is part of the popular Axminster Woodturning range. Made by us in Axminster, using the latest CNC production techniques, our world class chucks are the result of more than three decades of experience in production and design.
More from Axminster Woodturning
Turn eccentric pieces and spiral stems with this Axminster engineered and manufactured chuck accessory.
The Axminster Woodturning Eccentric Chuck locates onto any chuck with dovetail jaws 8mm deep with a 15° angle and that adjust to 70mm; such as the Axminster Woodturning type C dovetail jaws (100mm and 114mm) and other brands.
Full instructions from the designer, Tony Witham, are included. Expand your woodturning horizons, be eccentric.
British Made British Made
4.40 75
