The SB-25 floor pillar drill is an extremely robust 25mm (max. capacity in steel) drill. It is designed for large engineering and production tasks and is capable of being used for prolonged periods. Very heavily built and manufactured to exceptionally accurate tolerances, this pillar drill will stand up to hard work every day. The headstock has been machined to precisely match the quill housing, virtually eliminating any spindle run-out, even at full quill extension. The tolerance of the spindle runout (Quill movement) is + 0.01mm. Because the column is surface ground, the table rise and fall is super smooth in operation, making table height adjustment a light task. The high torque 750W motor drives the spindle via a 9-speed belt drive, (230, 340, 380, 500, 580, 600, 1,180, 1,350, 1,910), with machined steel pulleys eliminating vibration. Safety is provided for by a solidly made chuck guard, electrically interlocked, as is the belt cover. A large emergency stop button which locks closed automatically, completes the picture. Lighting is provided by an LED lamp with a flexible stem for ease of placement. This is a high quality floor pillar drill, designed to meet the demands of medium engineering and production workshops.
Heavily built, high precision floor pillar drill for engineers everywhere
750W high torque induction motor, provides plenty of power
Precision machined headstock and spindle quill casting for accuracy
9 belt speeds with machined steel pulleys for vibration-free running
Surface ground table, base and column aids accurate use
Electrically interlocked chuck guard and belt cover, plus locking "E" stop
Machine Classification
