Axminster Workshop Four Grit Diamond Hone
103263
From £5.78 £4.82
  5. Half Star
80 Reviews
  • 4 different diamond grits, double-ended & double-sided hone
  • Eachsurface 52 x 20mm, sharpen or touch-up many tools
  • Xcoarse 120grit, coarse 180grit, med 240grit and fine 320grit
This diamond hone gives you 4 different choices of diamond grit. The overall length is 180mm. Each end has a 52 x 20mm section of diamond coating. Double-ended and double-sided means you have 4 options. The grades are extra coarse 120 grit, coarse 180 grit, medium 240 grit and fine 320 grit. Each end has the grit size stamped into the steel so there is no confusion. This hone is useful for sharpening or touching-up many tools such as knives or router cutters.
4.50 80
