Axminster Woodturning Morse Taper Ground Sleeves
AX23283
AX23283
- Female tapered sleeves in four sizes
- Suitable for reducing Morse taper on tailstock or headstock
Show more
Show less
Tapered sleeves suitable for reducing the Morse taper on the tailstock or headstock of your lathe. These adaptors are intended primarily for large diameter drill bits or lathe centres. In certain instances male fittings may need to have a tang formed on the non-tapered part of the fitment (at the very end) so that they fit neatly into the adaptor.
