The AP254PS13 is a compact panel saw fitted with a 1,300mm sliding table. The sliding table has a pivoting support leg and a crosscut table. The sliding table gives 1,250mm travel past the blade. The support table can be positioned anywhere along the side of the sliding table. A telescopic work support fence extends to 1,850mm, and fits either the front or rear of the crosscut table. This can easily be removed without tools for storage.
The AP254PS13 has a cast iron and heavy gauge steel construction, which gives strength and vibration free operation. The 254mm blade offers a cutting depth of up to 80mm, powered by a high torque 2.2kW induction motor. The rip fence features a micro-positioning adjustment. There is a standard 19 x 10mm mitre fence slot in the main table. For smaller workpieces the mitre fence has an angle scale and cam-lock work clamp. Both the blade height and tilt controls are conveniently located and lock in position. Efficient dust extraction, smooth acting blade controls and an easily adjustable rip fence contribute to ease of use.
Included as standard are a 254mm Axcaliber TCT fine cut main blade, a rear feed-off table and table support legs.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Machine Classification
