Axminster Professional AP254PS16 Panel Saw - 230V
- Compact design perfect where space is limited
- 1,600 x 316mm fully featured sliding table
- Rear outfeed and side extension tables included
A compact yet capable saw
Perfect for where space is at a premium, the AP254PS16 Panel Saw delivers fantastic capacity and flexibility for everyday use.
So sure are we of the quality of this panel saw, we cover all parts and labour free of charge for three years! Find out more
Compact size
This panel saw has a compact footprint; ideal for those who are limited on space but still looking for impressive quality.
Scoring blade
Get an ultra clean cut with the 80mm scoring blade which can easily be adjusted, or withdrawn below the table.
Sliding, crosscut and support tables
The AP254PS16 has a 1600mm smooth running sliding table, a generous crosscut table, and rear outfeed and right hand support tables, allowing you to achieve a wide range of tough tasks including sheet work.
Efficient dust control
A 63mm crown guard hose clears the line from above and combines with a 100mm dust outlet to connect to a suitable extractor, giving you essential dust extraction to keep your workshop dust free.
Solid construction
Built with a professional workshop in mind, the AP254PS16 is dependable and made to last: heavy gauge steel chassis, cast iron table, a rigid rip fence and metal handwheels. Its construction will give you smooth, stable and vibration free operation, day in, day out.
Axminster Professional Overhead Crown GuardFrom £786.58 £655.48
The Axminster AP254PS16 Panel Saw offers outstanding cutting quality, capacity and flexibility in everyday use A robust chassis in heavy gauge steel and a generous grey cast iron table provide stability and vibration free running.
The 254mm main blade gives a maximum depth of cut of 80mm. The saw blade is carried on a heavy duty spindle ensuring accurate blade control and is driven by a multi V type belt for quiet operation with high reliability. An 80mm scoring blade is standard and is easily adjusted or withdrawn below the table by simple controls. The high efficiency main blade motor has a brake for safe stopping.
The 1,600mm sliding table runs very smoothly, carries a sizable crosscut table and includes a 2,000mm long, telescopic mitre fence complete with twin length stops. The crosscut table can be easily removed, saving space when not needed. Rear outfeed and right hand support tables are included for sheet work. The rigid rip fence has a sliding rail with high/low functions for all types of work. Cam locked to its rail, it is easy to adjust. The handwheel controls are smooth to operate and have retracting handles to save them being knocked. Dust extraction is provided with a 63mm hose on the crown guard leading to a combined 100mm dust outlet for efficient dust control when connected to a suitable extractor.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
Blade Diameter | 254 mm |
Blade RPM | 4,000 rpm |
Blade Tilt | 0° to 45° |
Bore Size | 30 mm |
Dust Extraction Outlet | 100 mm |
EAN Barcode | 5052511124602 |
Max Depth of Cut @ 45º | 57 mm |
Max Depth of Cut @ 90º | 80 mm |
Max Ripping Width | 870 mm |
Min Extraction Airflow Required | 1,300 m³/hr |
Model | AP254PS16 |
Nett Weight | 242 kg |
Overall L x W x H | 1,820 mm x 2,530 mm x 1,180 mm |
Plug Fitted | UK 16A Plug |
Power | 2.2 kW |
Rating | Trade/Professional |
Scoring Blade Bore | 20 mm |
Scoring Blade Diameter | 80 mm |
Sliding Table Dimensions | 1,600 x 316 mm |
Sliding Table Stroke | 1,600 mm with crosscut fence, 1,850 mm w/o crosscut fence |
Sound Power Level LwA [Uncertainty K] | 103 dB(A) [2.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 99 dB(A) [2.0 dB] |
Table Height | 912 mm |
Table Size | 1,020 mm x 1,193 mm |
Voltage | 230 V |
International delivery is unavailable for this product.
