Axminster Professional AP2552B Bandsaw - 230V
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Max depth of cut 200mm, max width of cut 340mm
- Extra large cast iron table, precision ground surface
- Smooth running, vibration-free balanced cast alloy blade wheels
High specification, modest price
The AP2552B bandsaw is a very popular sized machine for the trade or home workshop.
Welded Steel Body
The robust body of the bandsaw makes the machine rigid for more stability and an accurate cut.
Extra Large Cast Iron Table
With a precision ground surface, the table offers excellent support and a smooth cutting surface.
Deep Section Rip Fence
Supported front and back, the fence provides full support when ripping thicker pieces of timber.
Micro Adjustable Blade Guides
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Twin Trunnion Table Support
This provides excellent support and aids towards a vibration free cut.
Quick Blade Detensioning
This handy feature helps to extend the life of the blade, and save wear on the tyres.
Guide Height Control
For quick, simple and accurate set up, the guide height is both rack and pinion controlled.
Added Safety Features
There’s an adjustable T-slotted precision mitre fence as well as interlocked and micro-switched doors and an emergency stop switch to safeguard you while you work.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
The AP2552B bandsaw, with its high specification is a very popular sized machine for the professional or dedicated amateur.
The combination of a rigidly built steel body, large and finely ground cast iron table, deep section rip fence and micro adjustable ball bearing blade guides produces the high level of performance demanded by full time craftspeople. The rip fence runs on a calibrated aluminium extrusion and locks firmly in place with a lever, giving a solid and accurate location. The adjustable precision mitre fence is T-slotted into the table for added safety and accuracy. The table tilt quadrants are set very widely apart to give the maximum support to the table and to make the tilt action very smooth. Cutting depth is controlled by a well engineered rack and pinion system, with a lock to set the guides into position.
At the rear of the machine are the blade tracking control, the blade tension indicator and a quick action blade tension lever, useful for both blade changing and for releasing the tension on the blade when the machine is not in use. The powerful induction motor transmits its power via a multi-groove flat belt, ensuring smooth running and zero slip. Safety features include interlocked and micro-switched doors and an emergency stop switch.
Beautifully made and sure to please. Supplied with floor stand, rip fence, mitre fence and a 6tpi bandsaw blad.
Axminster Professional 3 Year Guarantee
Machine Classification
Bandsaw Blade Length | 2,552 mm (100.1/2") |
Bandsaw Wheel Diameter | 350 mm |
Blade Speed | 800 m/min |
Blade Width Min\Max | 3 mm to 16 mm |
Dust Extraction Outlet | 100 mm |
Max Cutting Height | 200 mm |
Max Width of Cut | 340 mm |
Max Width of Cut with Fence | 300 mm |
Min Extraction Airflow Required | 1,000 m³/hr |
Nett Weight | 84 kg |
Overall L x W x H | 690 mm x 720 mm x 1,770 mm |
Plug Fitted | UK 3 pin plug |
Power | 750 W |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 100.1 dB(A) [1.5 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [1.5 dB] |
T Slot Size | 19 mm x 9.5 mm (3/4" x 3/8") |
Table Height | 490 mm |
Table Height on Stand | 1,060 mm |
Table Size | 500 mm x 356 mm |
Table Tilt | 5° - 0° - 45° |
Voltage | 230 V |
