Axminster Professional AP25BM Bench Morticer - 230V
107638
Special Price £1,124.98 £937.48 was £1,249.98 £1,041.65 Save £125.00 £104.17
11 Reviews
In Stock - Ready to dispatch
  • Strong, heavy duty, cast iron construction
  • 25mm capacity in softwood, 19mm in hardwood
  • Single handwheel controls both table movements
Robust yet compact
A heavy duty machine, the AP25BM is ideal for a busy workshop and will offer years of dependable service.
3 Year Guarantee
Cast iron construction
The AP25BM Bench Morticer is produced almost entirely from cast iron, making this a strong and durable machine.
Smooth, one handed operation
Easily control the longitudinal and lateral table movement with one hand wheel.
Adjustable work stops
With lateral stops for repeat mortising and a depth stop which includes a haunch stop, the AP25BM can be used to produce a number of different joints.
Gas strut assisted head
Benefit from reduced fatigue and “parking” of the headstock in any position, thanks to the gas strut assisted headstock travel.
Effective timber clamp
The multiple position material clamp can accommodate a range of workpiece widths, enhancing the versatility further.
The AP25BM is a robust, compact bench mounted chisel morticer, produced almost entirely from cast iron. This strong, heavy-duty construction gives the machine capacities of 25mm in softwood and 19mm in hardwood. A single handwheel controls both longitudinal and lateral table movement. This system makes controlling the movement a breeze. The table has a tall back fence, with lateral stops for repeat mortising. The depth stop includes a haunch stop. The multiple position material clamp can accommodate different workpiece widths. A gas strut provides smooth downward travel of the headstock and also allows headstock "parking" in any position. There is an optional floor stand, plus also a very useful door mortising attachment.
This machine is well suited to a busy workshop and will provide many years of accurate and trouble-free service. It accepts chisels with either 3/4" or 13/16" shanks.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
5.00 11
