The AP60E is a thoroughly modern design of dust extractor with a cartridge filter as standard. The excellent performance comes from careful matching of the motor, impeller and housing, resulting in an efficient machine able to extract chips and medium sized dust from almost all small and medium sized machinery. The alloy impeller reduces the risk of sparks and the cartridge filter has a filtration rating of 1µm @ 100% capture rate. The cartridge filter increases the potential use of this machine to include sanders as well as the normal range of saws, planers etc. Easy to keep clean with the top mounted crank handle, the extra surface area means that the overall airflow is not significantly reduced. A large capacity plastic waste sack and quick release straps are included. A tubular handle, steel rear wheels and front castor wheels provide mobility.
Hose not supplied.
Generous airflow from the efficient alloy impeller
1µm @ 100% capture rate cartridge filter with high airflow
Extracts chippings and both coarse and medium fine wood dust
Machine Classification
