This is a medium sized, floor standing pillar drill. Cast iron and machined steel giving high strength, reliability and stability. It has a highly accurate chuck spindle assembly, running in NSK ball race bearings. Powered by a smooth running 750W induction motor, there are 12 belt speeds from 120 to 2,580rpm. The belts are of the multi-vee type for maximum grip and low vibration. The belt cover has a safety switch to prevent the drill being run with the cover open. The down feed is via a one-piece cast iron handle with soft rubber grips and there is an accurate drilling depth control. A quality 1-16mm keyless chuck comes as standard. The chuck guard is electrically interlocked for safety. The switch system has a separate locking emergency stop switch, plus a separate switch for the LED work light. Table height is controlled via a rack and pinion system; the whole table assembly can be swivelled away to allow the base to be used as a work support. A great choice for any trade or school workshop looking for a great performing floor standing pillar drill. Please note, this machine must be bolted to the floor for safe working.
Please note, morticing attachments are not suitable for this machine.
Smooth running 750W induction motor, 12 belt speeds 120 to 2,580rpm
Convenient rack and pinion table height adjustment
Quality 1-16mm keyless chuck and LED work lamp included
Machine Classification
