Edging clamps will clamp a lipping or edging to a board up to 60 mm thick. They have a throat depth of 50 mm. Screws on each side allow for off centre clamping. They are the same high quality as the Axminster Professional G clamp.
Lifetime guarantee.
Max clamping pressure - 250Kg
Clamp edging or lipping to board up to 60 mm thick
Designed to allow off-centre clamping
50 mm depth capacity, max clamping pressure - 250Kg
