Axminster Professional HD Parallel Jaw Clamp
- Jaws apply even pressure and stay parallel under load
- Unique swivelling handles to apply maximum pressure
- Reversible sliding head so clamp can be used as a spreader
Clamps that'll last a lifetime
As the name suggests, these clamps are all about staying parallel. Plus, with a clamping pressure hold of up to 710kg, there's no wonder we’ve also named these 'Heavy Duty' (HD) clamps.
Put your trust in our clamps
Discover their key features that will help with all your parallel clamping needs
Large clamping surface
All clamps have a face of 95mm which prevents damage to delicate surfaces; plus the pads are made from non marking material and can be easily removed for cleaning.
Ensures workpiece stays parallel
Built-in, hardened steel pins guarantee the clamp heads stay parallel and square.
Allow you to achieve greater clamping pressure with minimum effort from the user.
Extra support for clamp and workpiece
Support brackets keep the clamp level and stable when using on a work surface; plus it'll support and protect your project from any damage.
Effortless set up
A patented anti-slip system prevents the sliding head from sliding under pressure, allowing you to size your project up, then make the fine adjustments once the project is in place.
Multiple clamping uses
The sliding head is easily reversible, turning the clamp into a spreader.
See the entire rangeRecommended Accessories
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
Axminster Professional Bar Clamp RackSpecial Price £16.07 £13.39 was £23.98 £19.98 Save £7.91 £6.59
Axminster Professional Replacement Pads For HD Parallel ClampsSpecial Price £4.27 £3.56 was £6.38 £5.32 Save £2.11 £1.76
Axminster Professional Pair of Clamp SupportsSpecial Price £2.53 £2.11 was £3.78 £3.15 Save £1.25 £1.04
The Axminster Professional Heavy Duty Parallel Jaw clamp comes with a lifetime guarantee. The bar is zinc plated, cold drawn steel, profiled to minimise flexing and bending. Hardened rollers in the moving head maintain a constant 90° angle under load. A patented anti-slip system prevents the sliding head from sliding under pressure. The heads, encased in a glue resistant moulding are non-marring. The large clamping surface avoids damage to delicate surfaces. A unique swivelling handle allows you to apply greater clamping pressure. Supports keep the cramp level and stable when used on the assembly bench. The sliding head is reversible, turning the cramp into a spreader.
Clamp Throat Depth | 95 mm |
Clamping Pressure | 710 kg |
