Axminster Professional One Handed Clamp
From £10.63 £8.86 was £15.88 £13.23 Save £5.25 £4.37
82 Reviews
  • Glass fibre reinforced jaws and strong 20mm x 6mm steel bar
  • Simply squeeze the handles to operate
  • Throat depth 85mm, tough, non-marring jaw pads
See the entire range
With glass fibre, reinforced jaws and a strong 20mm x 6mm steel bar, these clamps perform well. The biggest advantage is their simple, single-handed operation, leaving one hand free to steady the work. Simply squeezing the handles to operate the clamp, results in great control. They have non-slip inserts and the rear handle houses the release trigger. An easily operated locking mechanism on the fixed jaw, locks or unlocks the jaw to convert the clamp into a spreader. The jaw pads are tough and non-marring with a little ‘give’ to grip irregularly shaped work. All sizes – 100kg max clamping pressure
Lifetime Guarantee.
Warranty Axminster Professional Clamps Lifetime Guarantee
4.8 82
