Axminster Woodturning Micro Handle & Set of 6 Tools
- Stainless steel handle with 6 interchangeable tools
- Perfect for pen, miniature and detail turnings
- Tools are high-speed steel
Customers Also Bought
The perfect tool set for turners working on small projects, pens and detailed or miniature turnings where precision and control are crucial. The set includes an Axminster Woodturning Micro Handle along with a set of six miniature tools. The handle is another example of precision engineering from our own manufacturing facility in Axminster. Machined from a solid stainless steel bar it has a gently contoured grip with light knurling to prevent it slipping in the hand. The tools comprise a round nose scraper, swan neck scraper, diamond side scraper, round side scraper, 6mm skew chisel and 6mm spindle gouge. These high-speed steel turning tools lock securely into the handle lock with two grub screws. The handle is 150mm long x 25mm diameter.
- Round nose scraper cleaning inside bowls and coves
- Swan neck scraper reaches difficult areas
- Diamond side scraper for finishing the bottom of boxes
- Round side scraper for undercutting
- Plus a 6mm skew chisel and 6mm spindle gouge
