A small benchtop sander is an invaluable tool for model or toy makers or woodworkers needing to adjust or finish small parts. The 25mm belt and a tilting table is well suited to profiling, finishing or denibbing. Around the corner is a 125mm diameter disc, provided with its own table and mitre fence and is suitable for end grain work and fine tuning angles and mitres.
All in all, this is an effective small sanding machine with a host of applications for the hobby and craft workshop. 45mm diameter dust extraction outlets are provided for both belt and disc. Supplied with a sanding belt and disc.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Small, disc and belt sander, perfect for toy and model making
Versatile machine for detail profiling, finishing or denibbing
125mm diameter disc provided with table mitre fence
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
