Perfect for the home workshop, this 150mm bench grinder runs quietly and smoothly. The motor has plenty of power for grinding or for cleaning if you wish to fit a wire wheel.
The eyeshields have magnifying lenses to help when sharpening. The guards feature built-in lights, which throw light exactly where it's needed. The steel rests are easily adjustable and the base has a built-in tray for either coolant water or use as a small storage drawer.
Fitted with 20mm wide 80G and 120G white aluminium oxide stones, the AW150BG is perfect for light sharpening and re-shaping tasks. White stones reduce the risk of overheating a chisel or blade (although it is still a good idea to keep dipping the edge in water to keep it cool).
An excellent machine for any small home workshop.
Note: When a grinder is new or when changing stones it is important to dress the stones to ensure the front face runs true. We recommend using a suitable dresser in order to get the most out of your grinder.
20mm wide; 80g and 120g white aluminium oxide white stones
Lights within the wheel guards illuminate your work
Magnifying eyeshields are a great aid when sharpening
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
