If you’re on the lookout for a table saw to help you achieve your woodworking ambitions, look no further. Robust, stable and with a large cutting capacity, the Axminster Workshop AW216TS Table Saw is one of our most impressive table saws for the home user; ideal for many types of crafts and DIY projects. Supplied with a right hand side table and rear extension table as standard.
Fantastic cutting capacity
Enjoy large, accurate and fast cutting 65mm capacity with this table saw; a real workhorse of any home workshop.
Stable and robust
The ground cast iron table allows your workpiece to run smoothly across the table while the rigid rip fence offers maximum support while you work.
Achieve multiple cuts
The AW216TS allows you to achieve a range of different cuts including straight cuts, mitred cuts and bevel cuts.
Ideal for a range of materials
Need to cut man made materials such as ply, MDF and sheet materials, or natural timbers including hardwood and softwood? Look no further.
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is usually reserved for much larger saws. This improves adjustability and allows for a smooth blade rise and tilt function.
Dust Extraction
The dust extraction on the AW216TS is highly efficient from both above and below the table. The crown guard connects to the main 100mm dust outlet via a sturdy 63mm hose.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
A table saw, perfect for the home workshop. The AW216TS saw features a quiet running 1,100W induction motor. The saw has a generous ground surface cast iron table with twin 19mm mitre fence grooves. It comes with a 216mm Axcaliber Premium 48 Tooth noise reducing blade, giving 65mm max depth of cut.
The whole motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, leaving the table completely unstressed. This design means that the blade tilt and height mechanism is exceptionally smooth. The table includes a pressed steel side extension and rear support table. The full length rip fence includes a 400mm sliding sub fence with high/low functions. Dust extraction is highly efficient from both above and below the blade. The single 100mm dust port is easily connected to a suitable extractor. The NVR switch has a separate locking Emergency Stop function for safety. Removable side panels allow easy cleaning and maintenance.
Also available as a package including the sliding table kit and leg stand (720848).
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
