If you’re on the lookout for a table saw to help you achieve your woodworking ambitions, look no further. Our powerful AW254TS Table Saw brings the cutting capacity of a trade workshop into the home workshop, making it ideal for many types of crafts and DIY projects. Supplied with a right hand side and rear extension table.
Fantastic cutting capacity
Enjoy large, accurate and fast cutting 80mm capacity with this table saw; a real workhorse of any home workshop.
Stable and robust
The ground cast iron table allows your workpiece to run smoothly across the table while the rigid rip fence offers maximum support while you work.
Achieve multiple cuts
The AW254TS allows you to achieve a range of different cuts including straight cuts, mitred cuts and bevel cuts.
Ideal for a range of materials
Need to cut man made materials such as ply, MDF and sheet materials, or natural timbers including hardwood and softwood? This table saw is just the ticket.
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is usually reserved for much larger saws. This improves adjustability and allows for a much smoother blade rise and tilt function.
Dust Extraction
Excellent dust extraction from above and below the table. The crown guard is connected to the main 100mm dust outlet via a sturdy 63mm hose.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
The AW254TS Workshop saw bench brings the cutting capacity of the trade workshop into the home workshop.
The saw features a quiet 1,500W induction motor, an important consideration in a residential neighbourhood. The generous ground cast iron table comes with the benefit 19mm mitre fence T-slots on the right and the left of the blade. A 254mm Axcaliber 50 tooth blade, offers a maximum 80mm depth of cut. The full length rip fence includes a sliding sub fence with high/low functions.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table. The result is exceptionally smooth operation and without any weight hanging beneath the table causing stress.
Efficient dust extraction from above the blade and below the table is brought to a single 100mm dust port for connection to an extractor.
The NVR switch includes a separate locking Emergency Stop function. Removable side panels to allow cleaning and maintenance.
The AW254TS is supplied with side and rear extension tables.
Also available as a package including the sliding table kit and leg stand (720849).
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
