Axminster Workshop AW2606B Bandsaw - 230V
- Resaw thick timber or cut thin veneers
- Large depth of cut: 200mm with 360mm width of cut
- Rigid, quick locking rip fence, cast iron table
A machine you can depend on
Whatever the task, this machine will accurately slice thin veneers or resaw large chunks of timber. Don’t forget to take a look at our wide range of blades for every task.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
Large capacity
A large cast iron table and ability to make deep wide cuts makes this a very versatile machine. The backbone to any home workshop.
Ball bearing blade guides
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Excellent dust extraction
With dual extraction ports, you can rest assured you’re safeguarding not only your health, but keeping your workshop clean at the same time.
Double trunnion table support
This provides excellent support and aids towards a vibration free cut.
Safety First
Supplied with push stick and interlocked doors for added safety.
Plenty of power
Supplied with a powerful alloy bodied motor with a multi v drive transfers maximum power to the blade.
How to get the best out of your AW2606B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Axminster Workshop AW153E Dust Extractor - 230VSpecial Price £299.98 £249.98 was £399.98 £333.32 Save £100.00 £83.33
Axminster Workshop MB-518 Light Duty Mobile BaseSpecial Price £41.92 £34.93 was £89.18 £74.32 Save £47.26 £39.38
Purchasing the AW2606B puts a powerful large capacity bandsaw in your workshop. A machine on which you can depend on to accurately slice thin veneers or resaw large chunks of timber, (we offer a wide range of blades for every task).
A powerful, quiet and reliable alloy bodied induction motor drives the bandsaw through a multi V-belt . A choice of two blade speeds, gives you the right speed for any task.
The AW2606B has a strong fabricated steel frame with a cast iron table and mountings. The generously sized, cast iron table has a standard 19mm mitre fence slot. The rip fence cam locks solidly to the front rail. Twin scales allow the fence to be used either side of the blade.
Bearing guides offer excellent support for increased accuracy. A rack and pinion system provides easy adjustment of the upper blade guide.
The two dust extraction points are interconnected and joined to a single 100mm outlet for coupling to a suitable extractor. Supplied with a splayed leg steel stand with rubber feet and a UK made general purpose blade.
Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
Bandsaw Blade Length | 2,606 mm (102.3/4") |
Bandsaw Wheel Diameter | 370 mm |
Blade Speed | 600 & 840 m/min |
Blade Width Min\Max | 6 mm to 19 mm |
Dust Extraction Outlet | 100 mm |
Max Cutting Height | 200 mm |
Max Width of Cut | 360 mm |
Max Width of Cut with Fence | 260 mm |
Min Extraction Airflow Required | 1,000 m³/hr |
Nett Weight | 85 kg |
Overall L x W x H | 980 mm x 760 mm x 1,740 mm |
Plug Fitted | UK 3 pin plug |
Power | 1.1 kW |
Rating | Home Workshop |
Sound Power Level LwA [Uncertainty K] | 98.5 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
T Slot Size | 19 mm x 9.5 mm (3/4" x 3/8") |
Table Height | 1,060 mm |
Table Height on Stand | N/A |
Table Size | 485 mm x 550 mm |
Table Tilt | 0° - 45° |
Voltage | 230 V |
International delivery is unavailable for this product.
