This extractor can be used in small home workshops for most common wood machining tasks where a higher airflow than provided by a vacuum extractor is required.
The quiet running induction motor provides power to extract from many small workshop machines. The inlet diameter is 100mm and the airflow is sufficient to handle the majority of waste likely to be produced in the small home workshop.
It is mounted on castors and has a grab handle for maneuverability around the workshop. Alternatively, It can be wall mounted, saving floor space, using the hanging brackets provided.
Please note that this is a chippings extractor and should not be expected to collect fine dust. As with all the high volume low pressure airflow machines, the inlet should not be restricted to below 75mm diameter and the bag should be emptied regularly. Spare bag provided.
Airflow: as measured in the Axminster workshop 640m³/hr @ 100mm.
Hose not supplied; see extraction hose selection for further details.
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
