Axminster Workshop No 1 Plane Blade
111862
111862
- High quality, 30mm wide plane blade
- High carbon steel, hardened and tempered to 60-62 Rockwell HRC
- Fits the Axminster Workshop No.1 Bench Plane
Show more
Show less
This 30mm wide blade will fit the Axminster Workshop No.1 Plane. It is made from high carbon steel, hardened and tempered to 60-62 Rockwell HRC, offering excellent edge retention. The high carbon steel offers excellent wear resistance and hold a good cutting edge. It comes with a 25 degree bevel. The blade only requires honing before use (putting a 30° micro bevel on the edge can be done in less than a minute).
EAN Barcode | 5052511136124 |
Plane Blade Width | 30 mm (1.3/16") |
