Bosch 32 Piece Mixed Screwdriver Bit Set & Holder
- Always have the right screwdriver bit for the job
- 31 bits plus 1/4" hex quick change magnetic bit holder
- Bits colour coded for quick identification
Customers Also Bought
With 31 screwdriver bits to choose from you’re bound to find the right bit for the job. To speed up your search the bits are colour coded for quick identification. These 1/4" hex, 25mm bits are S2 modified steel for longevity. The set includes a 1/4" hex magnetic, quick change bit holder. The robust plastic storage case features a transparent lit and a rear belt clip.
The bit sizes as follows:
Phillips: Ph1 x 1, Ph2 x 2, Ph3 x 1
Pozidriv: Pz1 x 1, Pz2 x 2, Pz3 x 1
Slotted: 3mm x 1, 4mm x 1, 5mm x 1, 6mm x 1
Torx: T10 x 1, T15 x 1, T20 x 2, T25 x 1, T30 x 1, T40 x 1
Security Torx: TH10 x 1, TH20 x 2, TH25 x 1, TH27 x 1, TH30 x 1, TH40 x 1
Hex: 3mm x 1, 4mm x 1, 5mm x 1, 6mm x 1
