The GCM 350-254 compound mitre saw combines precision with an exceptional cutting capacity.
It features a long list of very impressive specifications in this category of mitre saw. Not least is its 320mm width by 89mm depth cutting capacity. Even this can be increased by using self-made spacers to 100mm deep (by 250mm wide) or 350mm wide (by 60mm deep).
A dual-line laser indicates the cutting line left and right of the saw blade allowing you to position your workpiece exactly without having to retract the blade guard. The variable speed control (only on 230V machine) means the GCM 350-254 has the potential to deal with a variety of materials such as aluminium, PVC and wood. The 1,800W motor has a soft start, which stops any sudden jolt on pressing the switch.
Indents for common angles on both mitre and bevel functions make setting up for angled cuts fast and simple, and ensure repeatable accuracy time after time. For longer workpieces, the mitre saw has pullout extensions on either side to give extra support.
Blade changing is easy and quick with an SDS tool-less blade change system, useful when cutting different materials. At just over 24kg, the GCM 350-254 is no lightweight, however a carefully positioned carrying handle makes transportation balanced and relatively comfortable.
It comes with a material clamp, SDS blade nut and an Expert for Wood 254mm TCT blade.
Large cutting capacity, up to 100mm vertical and 350mm horizontal
Mitre angles 52° L and 60° R, bevel angle up to 47° L and R
Indents for common angles for quick setup and accurate repeat cuts
Dual-line laser for safer, speedier alignment with cutting line
Variable speed (230V only) allows use on wider variety of materials
Effective extraction with power tool extractor
Pullout side extensions for extra support of longer pieces
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
