This cordless router is extremely compact with a shape designed for easy single-handed use.
The Bosch GKF 12V-8 router fits perfectly in the 12V woodworking range of Bosch Professional tools and is fully compatible with the Bosch professional 10.8/12V batteries. This cordless compact router gives you the freedom you need when routing and trimming. It features the latest brushless EC motor technology giving you longer runtimes and a long tool lifetime. The small size and low weight offer a unique grip for complete control even when used one-handed. The large baseplate ensures increased stability.
The GKF 12V-8 has both fast initial, coarse cutting depth adjustment and micro depth adjustment for precise fine-tuning. For additional safety, a drop detection sensor shuts off router should it fall and a finger guard prevents accidental contact with the rotating cutter.
Supplied with a 1/4" collet. This is a body only tool supplied without batteries and charger.
Ergonomics: compact with full control when used one-handed
Cordless freedom: ideal for final trimming anywhere on site
Brushless EC motor: increased battery runtime and tool lifetime
Fine depth setting: micro adjustable for precise adjustment
Spindle lock: for easy and quick cutter changes
Drop detection: stops the tool running when dropped
Finger guard: prevents accidental contact with cutter
