The compact design and versatility make the GSA 18 V-LI C ideal for electrical or plumbing installation and remodelling or restoration work. Lightweight and perfectly balanced, it is easy to use one-handed, overhead or working in inaccessible areas. The variable cutting speed allows cutting of a wide variety of materials. The GSA 18 V-LI C is capable of cutting 200mm in wood or 100mm in metal. The SoftGrip and low vibration levels ensure comfortable use and minimise fatigue. An LED light helps to give you a clear view of the workpiece during sawing. Blade changing is a simple matter thanks to the SDS tool free collar. This is a body only tool, you can utilise batteries from any other Bosch 18V Li-ion tool. Bosch Li-Ion battery technology is premium quality and provides the longest possible battery life and runtime.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied without batteries, includes L-BOXX.
Versatile, ideal for electrical or plumbing installation and remodelling
Lightweight and perfectly balanced, easy to use one-handed,
Compact, for overhead or working in inaccessible areas
Variable cutting speed, suitable for a wide variety of materials
SoftGrip and low vibration levels minimise fatigue
LED light illuminates the workpiece during sawing
Simple blade changing thanks to the SDS tool free collar
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
