The Bosch GTS 635-216 table saw is a compact saw with large cutting capacities. The redesign of the motor/gearbox configuration maximises the cutting height from the 216mm blade. The result is a highly portable saw bench with a maximum depth of cut of 70mm and a cutting width of up to 635mm.
The extruded aluminium rip fence locks front and rear for precise, parallel rip cuts every time. Removing the face of the fence, laying it flat and re-attaching it forms a low fence for safe cutting of thin workpieces. The 1,600W motor provides all the power required to handle 70mm at full capacity.
Safety is paramount; the GTS 635-216 features a soft start, restart protection, a safety switch with emergency stop and efficient dust collection (when connected to a suitable vacuum extractor).
The machine is easy to transport with its ergonomic handles and low weight of 22kg. All the accessories can be stored on the machine; a place for everything and everything in its place, nothing gets lost. Its compact size makes it a good choice where space is limited, as it will fit neatly under a bench when not in use. For site work, a stand is available turning it into a useful saw bench with great capacities.
Supplied with TCT blade, mitre fence and push stick.
1,600W compact saw with big capacities
70mm max depth of cut, 635mm max width of cut
Highly portable, weight 22kg
Fence locks front and rear for precise, parallel cuts
Safety switch with emergency stop
All the accessories can be stored onboard
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
