The Bosch Isio Shape & Edge Shear is a cordless edging tool that is both light and powerful, enabling a range of gardening tasks from lawn edging to shrub trimming to be undertaken with the minimum of effort. It is powered by a 3.6V 1.5Ah Li-ion battery which will provide a running time of up to 50 minutes from one charge. A lightweight charger is supplied. It also incorporates the Anti-Blocking System which means the machine won’t stall in use. Two types of cutting head are supplied: the 110mm shrub shear blade and the edging shear allowing grass edges to be cut neatly. Each attaches to the handle unit by the unique Multi-Click System, making it seconds to swap between blades. Supplied in a soft, zipped carrying case with two blades and a charger.
Shrub shear blade, shape shrubs and bushes
Edging shear blade for grass
Anti-Blocking System for the best performance
Single charge will give up to 50 minutes running time
Multi-Click System for easy blade changing
Charge indicator
3.6V 1.3Ah Li-Ion battery - no self discharge, always ready to use
Bosch DIY 3 year warranty available (registration required)
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
