Bosch T144DP Jigsaw Blades Fast Precise Wood Cuts
- 50mm soft wood, chipboard, fibre board, kitchen worktops, doors and plywood
- Supplied in packs of 5
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Soft wood 50mm, chipboard, fibre board, kitchen worktops, doors and plywood.
Blade Type | HCS, Ground and Side Set |
EAN Barcode | 3165140264181 |
Jigsaw Blade Length | 51 mm |
Jigsaw Blade Type | Precise Cuts |
Max Cutting Depth | 50 mm |
Model | T144DP |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
