Bosch T308BF Jigsaw Blades Tear Free Hardwood (Pkt 5)
701879
701879
- Hardwood and high quality laminate cutting
- Fast clean cutting on both sides of work
- Two rows of different style teeth
- Scalpel tooth and pointed tooth
- BIM longlife blades
- Pack of 5
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Show more
Show less
Clean accurate and tear free on both sides of the hardwood and laminate material. Two rows of teeth arranged at different angles, a razor sharp scalpel tooth will cut the wood fibres on the reverse whilst a precision ground pointed tooth separates the wood fibres on the top surface and give super clean cuts. BIM longlife blades suitable for hard wood and high quality laminate boards.
Blade Type | Bi-metal, Ground |
EAN Barcode | 3165140470322 |
Jigsaw Blade Length | 91 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 20 mm |
Model | T300BF |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 2.20 mm \ 11.5 tpi |
