Bosch T301CHM Jigsaw Blades Clean Cut Solid Plastic (Pkt 3)
- Designed for cutting Corian®
- Solid surface materials such as Varicor®
- Tungsten carbide tipped, extra long life blade
- Clean, chip-free cut, special tooth geometry
- Suitable for CRP sheet, pipes and profiles
- Pack of 3
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Especially designed for cutting Corian® and similar solid surface materials such as Varicor®. This blade has extra long life HM/TC tooth to cope with these materials and will leave a clean, chip-free cut having special tooth geometry. Suitable for CRP sheet, pipes and profiles. Pack of 3.
Blade Type | TCT, Ground Teeth |
EAN Barcode | 3165140691543 |
Jigsaw Blade Length | 100 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 65 mm |
Model | T 301 CHM |
Pack Quantity | 3 |
Tooth Pitch \ tpi | 3.18 mm \ 8 tpi |
