Bow XT T-Track Clamps
- Attach the XT Xtender fence to existing fence
- Work seamlessly with the XT Xtender Fence system
- Can also be used for general clamping
Unparalleled control, precision, and versatility
The revolutionary BOW XT Xtender Fence range will become your number one companion when it comes to sawing. Here are the key components that make it so impressive:
The fences
Strong, rigid and durable, the fences are engineered in heavy duty aluminium extrusion and are available in 24”, 36” and 46”. They will extend your existing saw fence by these lengths respectively, drastically improving your support on any site saw, compact table saw or bandsaw.
The clamps
Coming as a pair, these classic T-Track clamps are designed perfectly for the XT Xtender range. They slot securely into the milled T-tracks of the fences.
The feed supports
Able to be positioned in front of the blade or behind, these supports do just that…significantly improve support for your work. Plus, you can slot a standard 2x4 into the cavity underneath to give even stronger support.
The system
- Each fence has multiple milled T-slots
- Effortlessly attach the XT Xtender fence to existing fence
- Position it best for you: forward/infeed, centre, or back/outfeed
- Easily set up, remove or change the fence position in seconds
The benefits
- Remarkably versatile
- Quick and convenient
- Use anywhere – onsite or in a busy workshop
- Easy storage with hanging hole on the fence
Most importantly: better support, better safety, better cut quality, better feed control.
The BOW XT T-Track Clamps are an essential accessory, designed to work seamlessly with the XT Xtender Fence system.
Sold as a pair, the XT T-Track Clamps have a 2 1/2" throat and 5" opening. Using the milled T-Tracks on the XT Xtender Fence, they securely clamp the XT Xtender Fence onto the existing fence of your saw, quickly and easily. They can also be used for general clamping, making them a versatile addition to your toolkit.
EAN Barcode | 853223006515 |
