Bushing Set for Tweezer Kit
- Enables you to accurately size your project
- Helps to speed up production
- Turn project kits with confidence
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
The bushing set you need to make our Tweezer Kits. The use of a pen mandrel with the correct bushing set makes turning project kits an easy process. Simply use the bushings on the mandrel as a reference to turn your blanks down to the correct diameter.
EAN Barcode | 840229914524 |
